11-09-2018 11:34 AM - edited 03-17-2019 01:42 PM
I need to send fork call audio to multiple destinations simultaneously. I have two recording servers and need to record same call to both. Right now I have configured them as SIP trunks and put them in a route group - route list construct. However, this only allows me to record to the highest priority server.
Is there a service parameter or feature that I can use to modify this behavior? In other words, even though the first trunk responds successfully, CUCM should still forward the call to the next.
Solved! Go to Solution.
11-09-2018 11:40 AM
No, currently that is not possible.
If you're with a partner, you might want to review this session:
https://community.cisco.com/t5/collaboration-documents/collaboration-voe-july-26-2018/ta-p/3706394
11-12-2018 01:32 AM
if the servers are connected to the same switch or otherwise geographically not to far away
you can create a network monitor (SPAN) port on the switch for rtp traffic, or use a hardware device ( data - TAP),
to duplicate the data from one network connection to the other.
Use this link for rtp traffic only, use another network connection for management of the recorder.
11-09-2018 11:40 AM
11-09-2018 11:59 AM
Java,
Thanks for responding. I'm not with a partner and was unable to access the link you sent.
11-09-2018 12:05 PM
OK, then reach out to your SE and discuss this with him, he'll have access to the link and can provide you with the answer.
11-12-2018 01:32 AM
11-13-2018 08:53 AM
Thanks for the suggestion. The servers are at different locations about 5-6km apart. SPAN/RSPAN certainly seems like the only option at this point. I'm going to explore this further.
