Forward a call to cell phone
NAVIN PARWAL
Level 2
Level 2
Folks,
I have ccm4.1(3) is it possible to foward a call to my cell phone if i am not at my desk without hitting the call forward all button, I am looking for something like follow me feature in which if my desk phone does not answer, the phone automatically tried my home phone or cell phone.
6 Replies 6
icabrera
Level 4
Level 4
Hi, you can ask the ip telephony administrator at your company to do this.
At the ccm admin phone settings there is an option for "forward no answer" that it's exactly what you need.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed74c.html#wp1245287
Pls,rate if helpful
jolo07310
Level 5
Level 5
There is no such automatically to forward the call to your cell phone.
Couple methods you can try:
1. If you have internet access when you are outside, you can use https://CCM IP adress/ccmuser through your company VPN to forward your call to your cell.
2. Go to CCM web page, put your cell phone at "Forward No Answer" under line configuration.
3. Call into Unity if you use Unity, ask Unity to forward your call to your cell phone.
4. Get a 3rd party tools, I have seen a company install the tools, when someone call your IP Phone DID, it will ring at Cell phone, pager, and IP phone at the same time. I dont know what tools, hopefully someone knows at this forum.
Ken
thank you very much for the response.
I know that call forward no answer would not forward the call to an external number. Am I right?
I do not want to VPN or press call forward all either, how can i call into unity and have it forward the call to my cell phone if i am away as you mentioned?
Here is the step:
1. call the unity
2. press *, then enter your extension follow by #
3. enter password follow by #
4. press 4
5. press 4 again
I havent tried myself, you might need further configuration or setting at Unity. If I find something at cisco, i will let u know.
Ken
Cisco actually has the Mobility Manager product, which handles #4:
http://www.cisco.com/en/US/customer/products/ps6567/index.html
Not applicable
