forward-all in SRST-modus
antoinemeunier
Beginner
Beginner
I have understood that when an IP-phone is falling to SRST mode, the forward all destination that was configured will disappear.
I want to know if it is possible to configure a forward all destination when the IP-phone is in SRST mode?
Do I have to configure something special under the call-manager-fallback option?
Thanks a lot,
Best regards,
Antoine Meunier
ronpatel
Collaborator
Collaborator
Basically, under call-manager-fallback you will need to set up the alias
command.
The following is the example:
Call-manager-fallback
alias 1 3016921743 to 3016921743 preference 1 cfw "Cell phone number"
timeout 10
With that set up if someone calls the number 3016921743 and if that number
is register to the SRST router the call will be sent to the cell phone
number after 10 seconds.
In the following link you will get some documentation about it.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/srst_call_handling.html
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hello Ronak,
Thanks for the answer.
However, what I would like to know, is that if users are able to activate a forward all when the IP-phone is in SRST mode, just the same way the do in normal mode.
Thank you,
Best regards,
Antoine
