ā10-21-2019 09:41 AM
I'm trying to set up translation rule on our CUBE to take incoming DID and send/translate it to a local DN. I've set up translation rule, for this instance lets say that incoming DID is 904-123-4567 and local DN that should be sent to is 5500.
I've set up this translation rule:
voice translation-rule 3
rule 1 /^9041234567$/ /55000/
rule 2 /^19041234567$/ /55500/
I have that translation rule applied to a translation profile:
voice translation-profile translate_test
translate calling 3
And from there I have the translation profile applied to outgoing dial-peer from CUBE to CUCM. However I can't seem to get this working. Any suggestions?
ā10-21-2019 10:07 AM
You configured it as a calling number rule, that's the ANI.
ā10-21-2019 10:14 AM
Isn't ANI the calling number?
Is it possible to do what I'm trying to translation-rule?
ā10-21-2019 10:17 AM
Under translation profile, instead of using "translate calling" you need to use "translate called". And you need to apply this translation profile on PSTN incoming dial-peer. Here is the configuration example:
voice translation-rule 1 rule 1 /^9041234567$/ /5500/ ! voice translation-profile PSTN_Incoming translate called 1 ! dial-peer voice 100 voip description *** INBOUND CALLS FROM SERVICE PROVIDER *** translation-profile incoming PSTN_Incoming incoming called-number . <Apply rest of the dial-peer configuration based on your scenario> ! dial-peer voice 101 voip description *** OUTBOUND CALLS TO CUCM *** preference 1 destination-pattern 5500$ session target ipv4:10.10.1.10 <Apply rest of the dial-peer configuration based on your scenario> !
ā10-21-2019 10:23 AM
ā10-21-2019 10:50 AM - edited ā10-21-2019 10:51 AM
The earlier example was for 5500. If you want it for 55000 then update the translation rule and dial-peer destination pattern. Can you post your full router configuration?
ā10-21-2019 10:53 AM
ā10-21-2019 12:43 PM
Please post "debug voice translation" while making the call.
Also, have you tried doing it on CUCM via translation pattern?
