Beginner
Forward issues
Hii,
I have cucm 10.5 with 2x 2921 Voice Gateway  and 12 E 1 lines. When on my extension (2312) I activate the forward  to 00742334772 and when somebody from out said Continental tray to call me on the internal extension (2312) the forward sent only the last 4 digit from the calling number ( 3421) and not the all digit 07421253421.
My question is this can be from provider or is from the cucm.
Thanks for help
6 REPLIES 6
Hi,Do you experience the same
Do you experience the same issue when calling from an internal IP phone to this extension? What are the calling party transformation settings on the Route pattern or gateway / trunk?
Manish
Beginner
When I call from an internal
When I call from an internal phone the forward work fine
Hall of Fame Master
What is the GW configured as
What is the GW configured as in CUCM, is it SIP/MGCP/H323? You need to make sure you send the diversion header/redirecting number to the GW.
Beginner
The protocol is MGCP.
Beginner
Rising star
Hello gabiulici,In addition
Hello gabiulici,
In addition to what has already been stated, you can run a "debug isdn q931" to see what is being sent to your telco.  Telco issue or Callmanager issue?
I just ran a debug on our system and I see the original calling number as well as the redirecting number.
Hope this helps,
please rate helpful answers.
Thanks.
Content for Community-Ad
August's Community Spotlight Awards
