04-28-2015 06:53 AM - edited 03-17-2019 02:49 AM
Hi all,
I have a
How can I fix this?
Thanks all.
Solved! Go to Solution.
04-28-2015 07:41 AM
Is the call forward to an external number? cell phone?
Is the call forward/caller-id working when the call is forwarded to an internal phone?
If the call is forwarded to an external number, you can run a
debug isdn q931
on the gateway and verify if Callmanger is sending out the caller-id and the redirecting number.
04-28-2015 07:41 AM
debug isdn q931
04-28-2015 07:54 AM
Hello Charles,
This is a DS1 SVPRI connection.
04-28-2015 08:57 AM
Not sure about the SV part of SVPRI. Haven't had the opportunity to work with SVPRI.
I would try it to verify if it works or not.
Login to your gateway and
term mon
debug isdn q931
and make test call.
Hope this helps...
