09-09-2016 07:32 AM - edited 03-18-2019 12:06 PM
I have a request to forward a line after no one has picked up to a different extension but if that person doesn't pick up have the original forwarding extension pickup.
In Short;
extension 1111 forward to 2222 if no answer
if there is no answer on extension after being forwarded to 2222 forward back to voicemail back to extension 1111
Both extensions currently have voicemail configured and we are running CUCM 10.5 and CUC 10.5
Any suggestions are greatly appreciated
Nick
Solved! Go to Solution.
09-09-2016 07:52 AM
Hi Nick,
Unity Connection should work this way by default. If you set the FNA on 1111 to roll to 2222 on no answer and then set the FNA on 2222 to roll to your voicemail pilot on no answer the call will eventually end up receiving the greeting for 1111 on end up in the 1111 mailbox. The only way this won't work is if you've changed the Advanced setting in Unity Connection from "use original dialed number" to "use last redirecting number."
Cheers!
Rob
09-09-2016 07:52 AM
Hi Nick,
Cheers!
Rob
09-09-2016 08:12 AM
Thanks! It was just as you described
Thanks again,
Nick
09-09-2016 07:54 AM
Unless you have changed the default CUC configuration, that's the behavior you'll see. The original called number is used to choose the mailbox, not the last redirecting (unless you change the default config to have the latter)
Have you tried this??
09-09-2016 11:56 AM
Hi Nick,
You are most welcome my friend! Glad you got it sorted.
Cheers!
Rob
