02-04-2013 08:40 AM - edited 03-16-2019 03:31 PM
Hi voice team,
i´d like to know, how to transfer the voice messages to a cellphone and email.
The user can listening the messages on both devices (cisco phone and your personal cellphone and email).
Thiago Gandara
Solved! Go to Solution.
02-06-2013 05:42 AM
I talk to the client and he wants the SMTP notification, just an alert, to make this configuration a need a smart host configured, thats right?
Thanks.
02-06-2013 06:03 AM
for Cell phones , the below is just an example.
On CUCM I'd create an ext phone (your IP phone) with the DID and do a CFNA/CFUnregistered and send it to UCxn,
like every other phone. all calls will go directly to voicemail. In Unity Connection, I go to my profile for my IP phone voicemail box and set +14092228888 (as my mobile phone) as an alternate extension.
so the call is sent to Unity Connection.Unity Connection matches the number as an Alternate Extension to my production IP phone,
02-06-2013 06:12 AM
For SMTP (text) notification, yes...you need a relay server and also configure the notification for that user's mailbox. See the following:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsag200.pdf
Hailey
02-06-2013 07:37 AM
Ok, David.
I managed to configure the voice message is sent to the cellphone, but the recording asks to enter the pin, I type but nothing happens, the recording asks for the pin again, it seems that is not accepting the digits of my cellphone.
thanks.
02-07-2013 07:47 AM
Thiago, this is likely a DTMF issue. There are a few different variables and is likely related to a configuration on the voice gateway that terminates the PSTN connections (are you using POTS, PRI, or SIP trunk)? Is the integration for Unity Connection using SCCP (i.e., you have ports configured in CUCM) or SIP (i.e., you have a SIP trunk from CUCM to Unity Connection)?
Hailey
02-07-2013 08:00 AM
Hi David, im using E1 Link, POTS. The unity its integrated to CUCM using SCCP protocol. I have 16 ports configured in my CUCM.
Thanks.
02-07-2013 08:34 AM
I see the debugs and after put the line: " incoming called-number . " on dial-peer voice 1 voip, a can enter the pin and listen my messages.
Thanks.
02-08-2013 07:24 AM
Hi David, is possible remove pin on notification device for my user, so when a voice message arrive at my phone I don't need to digit my password and listen the voice message?
Thiago
02-08-2013 07:29 AM
Haven't tried this on a notification outcall so you'll need to verify the behavior:
You can define the cell phone number as an Alternate Extension for the user's mailbox. Then on the basic properties for the user's mailbox, select the Skip PIN when calling from a known extension option.
Hailey
Please rate helpful posts!
02-08-2013 08:32 AM
Ok, I will do this test.
Thanks.
02-13-2013 05:35 AM
Hi i do the test, but my cellphone dont ring.
Do you have any procedure that show me how to configure alternate extension?
Thanks.
02-13-2013 05:47 AM
Thiago,
The alternate extension doesn't ring your cell phone. That is the notification configuration. You need to read the following:
The Alternate Extension is set under the mailbox by selecting Edit > Alternate Extensions. It is an alias or a way to associate a number that is not the primary extension to the mailbox so that the system can recognize multiple numbers for a user and direct them to same mailbox.
02-13-2013 05:53 AM
Ok, the device notification works, i cant configure the alternate extension.
02-13-2013 05:58 AM
02-13-2013 07:44 AM
Hi, i do this, but when i put my cellphone as alternate extension, nothing happen. It doesn't ring
