Forwarding ip phone issues
dianearsenault
We are using cisco unified cm administration.  We have a phone that can not successfully connect to any forwarded number when we set up forwarding through the software interface. We can successfully place a call to the same forwarded phone number if we manually set forwarding on the physical phone.
 We have looked up and down the software settings on this phone and can not find the issue.
This is the same whether or not we set phone forwarding in cisco unified cm administrator or ccm user.  We are unable to reach the forwarded number and get a "The number you are trying to reach is not in service--or a similar recording".
Anyone with any ideas?
Thank you!
2 Accepted Solutions
Robert Shaw
Level 3
Level 3
Does the Call Forward CSS configured on the phones Directory number contain the required Partition to be able to dial the forwarded number?
Rob
Mohammed Khan
Do you have the right calling search space configured for Call forward on Directory number configuration?
Robert Shaw
Level 3
Level 3
Rob
Thanks, applied your settings and this worked.
Mohammed Khan
