Forwarding Number Translation Pattern
gmcvb
SNR and CFA to external numbers are not working following a cutover to a different phone carrier.
I was talking with somebody else and thought I needed to set up a forwarding number translation pattern.
I'm not entirely sure how to set that up, if that might be the issue.
UC sys version is 8.6.2.21900-5
Any suggestions appreciated... thanks!
Well it's not hard at all, or more to the point, that depends on how you have designed your PT/CSS setup.
What you need to do is create one ,or more if needed, TPs in a PT that is seen by the CSS used for SNR (reroute) or CFA. If you only want this/these TPs to be used in these two particular use cases then see to that the PTs is only seen in CSSes used for SNR or CFA.
Please rate all useful posts.
Response Signature
