Beginner
Forwarding to Unity Connection
I feel like I'm overlooking something simple here.
Phone A extenstion is forwarded to Phone B extension.
When someone calls Phone A's extension, and Phone B ultimately forwards this to voicemail, Unity Connection plays the greeting of Phone A (based on the Called Number).
Is there a way for Unity Connection to play Phone B's voicemail (based on the last redirecting number) in this scenario?
TIA
Ryan
Everyone's tags (2)
2 REPLIES 2
Beginner
Re: Forwarding to Unity Connection
Never mind I found the parameter of Use Last (Rather than First) Redirecting Number for Routing Incoming Call
under System Settings -> Advanced -> Conversations
Ryan
Hall of Fame Cisco Employee
Just so you know that's the default behavior you'll find on CUC and Unity, always use the original called number to determine which mailbox to reach.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Content for Community-Ad
August's Community Spotlight Awards
