Four DN's to ring one FXS Port
rmckerrall1
Beginner
Beginner
I have four separate DN's on a phone that all need to ring to a single FXS port (external ringer).
I realize that I can create a broadcast hunt group for each line and have it ring the phone and the external ringer extension but this is a messy solution. I could also hook up four external ringers to four separate FXS ports on a VG204.... also messy.
Any other suggestions?
Just add a translation pattern to map the four numbers to the 'real' single number you assign to the FXS port.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Aaron,
If I add a translation pattern it will only ring the FXS port number and not the extension on the phone itself, I need the phone and the ringer to ring simultaneously. Am I missing something?
Rob
I see.
Hunt groups would be one way.
Another way might be to set up the ringer as a remote destination and link that to the lines. Probably also quite messy.
Aaron
