06-10-2013 01:29 PM - edited 03-16-2019 05:47 PM
We have a mid-size office environment with less than 100 users
In the last few weeks, we have noticed a growing number of fraudulent calls to overseas countries. None of the employees indicated that they called any of the numbers. As well none of the numbers have ever been called before . Before this peried,
We suspected that there is an infected machine/process someplace that is able to access the local network and initiate outbound calls. we are worried that it may also try to send out some files without our knowledge.
We have disconnect the rtr from the phone lines to prevent any further LAN initiated calls. Users now use POT sets
we have a 2821 rtr running ADV IP Services 12.4(24) t8, With CME for the VoIP users
We have both VIC2-2FXO and VIC2-2FXs cards
in front of that is a ASA 5505 in transparent mode running IOS 9.12-k9
we do not actually know if this is a user, process or some Trojan horse that has woken up
I am looking for solution to how to track, control, and/or disable these unwanted calls -
My cisco SE is asking around for this issue. so far, he told me to try this
""you can have CDR (call detailed record) on the router itself, but you are limited by 100 records or so. Alternatively, you can offload to an external server for logging."
http://www.cisco.com/en/US/docs/ios/voice/cdr/developer/guide/cdrcsv.html
Any help would be useful.
thank you
walter
Solved! Go to Solution.
06-12-2013 05:57 AM
You are being exploited from the Internet, as is very normal for installations done without taking adavantege of the expereince of a reputable consultant.
Check: http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a00809dc487.shtml
06-12-2013 02:24 PM
You are welcome, please remember to rate useful posts clicking on the stars below.
06-11-2013 09:45 PM
Listed below is a sample from the CME CDR log
it appears that there is a rouge app somewhere on the network attempting to make outbound calls to Isreal (cc=972, see below)
It is emulating ephone 1001, which is not a vlaid ephone number in the rtr config
i am looking for some s/w that can better decode the UCME/CME CDR format. so far all i see are ones that support UCM/CM CDR formats.
i understand that these two formats are much differant
any suggestions for a UCME/CME app to decode the CDR logs?
1370984963,11454,0,2,"EBADA50A D21111E2 9BF39CD4 3FA3E5CA","","","16:08:38.492 NewYork Tue Jun 11 2013","","16:08:42.162 NewYork Tue Jun 11 2013","16:09:23.892 NewYork Tue Jun 11 2013","","","answer",0,"",1740,278400,8,1280,"1001","1001","972598769442","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","",42,"","","25","","","","","","","","","","","","","","","","","","","","","","","ton:0,npi:0,#:972598769442","ton:0,npi:0,pi:0,si:0,#:1001","","","","","","","","","","count:1","","Unknown","","","sipv2","","","TWC","06/11/2013 16:08:38.491","1001","972598769442",0,11392,EBADA50A D21111E2 9BF39CD4 3FA3E5CA,2CBE,"","","","","",""
;1370984963,11455,0,1,"EBADA50A D21111E2 9BF39CD4 3FA3E5CA","","","16:08:38.514 NewYork Tue Jun 11 2013","","16:08:42.154 NewYork Tue Jun 11 2013","16:09:23.944 NewYork Tue Jun 11 2013","","","originate",0,"",1740,278400,8,1344,"1001","1001","972598769442","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","",42,"Tariff:Unknown","","0","","","","","","","","","","","","","0/5:1","","","","","","","","","","ton:0,npi:0,#:972598769442","ton:0,npi:0,pi:0,si:0,#:1001","","","","ton:0,npi:0,#:2598769442","ton:0,npi:0,pi:0,si:0,#:1001","","","","","","","Unknown","","Vonage-VoIP","","","","TWC","06/11/2013 16:08:38.507","1001","972598769442",0,11393,EBADA50A D21111E2 9BF39CD4 3FA3E5CA,2CBF,"","","","","",""
1370984976,11457,0,2,"9345B99 D21211E2 9BFA9CD4 3FA3E5CA","","","16:09:28.028 NewYork Tue Jun 11 2013","","16:09:31.888 NewYork Tue Jun 11 2013","16:09:36.378 NewYork Tue Jun 11 2013","","","answer",0,"",148,23680,6,960,"1001","1001","912462562918","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","",4,"","","0","","","","","","","","","","","","","","","","","","","","","","","ton:0,npi:0,#:912462562918","ton:0,npi:0,pi:0,si:0,#:1001","","","","","","","","","","count:1","","Unknown","","","sipv2","","","TWC","06/11/2013 16:09:28.032","1001","912462562918",0,11394,9345B99 D21211E2 9BFA9CD4 3FA3E5CA,2CC1,"","","","","",""
Message was edited by: walter baziuk add cme router CDR files
06-12-2013 05:57 AM
06-12-2013 02:13 PM
Hello Paulo
Thank you fo rthe document. I think it will work for me!!
i have added this to the top of my incoming ACL
As i dont need any other SIP unit to call my cme, i want to drop all incoming sip calls or anything that could use my CME
remark ============ *** Toll Fraud prevention
deny udp any eq 5060 any
deny udp any any eq 5060
deny udp any any range 16384 32767
is there anything alese that i used do to stop incoming calls.
so far , this is what my new ACL is dropping
Extended IP access list incoming-traffic
10 deny udp any eq 5060 any
20 deny udp any any eq 5060
30 deny udp any any range 16384 32767 (2121matches) <- after 2 hours
walter
06-12-2013 02:24 PM
