10-24-2017 03:10 PM - edited 03-17-2019 11:28 AM
Is it possible to go from call manager express to full cucm? We are currently using sip to reach our service provider but after we attempted to configure chuck we are unable to make calls outside our network. We deleted every single statement that had anything to do with CmE on the router & only left the dhcp statements as well as the option 150 statement that points to our cucm server. Is there a statement that maybe I am missing on the router that will allow our phones to reach the service provider.
We are using cucm 10.0.1
have comfigured phones & sip profiles as well as a sip realm since we need a username & password in order for the calls to connect & we are still not able to make it work. Yes we also have configured a sip trunk.
Any ideas would def help since we have not been able to get this working.
Solved! Go to Solution.
10-24-2017 04:56 PM
So if I am correct you had CME before and went to full blown CUCM? The CME router would then be a cube router and would need a sip trunk from CUCM pointing to it. You would also need dial-peers for each call leg.
10-24-2017 04:56 PM
10-24-2017 08:25 PM
10-25-2017 06:17 AM
Post your GW config along with "debug ccsip messages" letting us know the called and calling party.
