FTP PATH for GW-ACCOUNTING Contains Spaces
I'm testing the app imagicle which contains CDR capabilites
I'm trying to set de FTP path for the cdr records but it contains spaces:
The FTP path is :C:\Program Files (x86)\StonevoiceAS\Apps\BillyBlues\Engine\ccm_express\1
When I try to configure it in CUCME i get error because of the spaces in the path:
UC-SK(config-gw-accounting-file)#$50.93:21/C:Program Files (x86)\StonevoiceAS\Apps\BillyBlues\Engine\ccm_express\1 username danny password 7 06545B711D1C5D59
 primary ftp 192.168.50.93:21/C:Program Files (x86)\StonevoiceAS\Apps\BillyBlues\Engine\ccm_express\1 username danny password 7 06545B711D1C5D59
% Invalid input detected at '^' marker.
Is there any workaround on this?
Thanks in advance
Alejandro
Jaime Valencia
Probably because you're dead wrong in how you're configuring that
You use a relative path there, how could you try the full path???
http://www.cisco.com/c/en/us/td/docs/ios/voice/cdr/developer/guide/cdrdev/cdrcsv.html
http://resources.esri.com/help/9.3/ArcGISengine/java/Gp_ToolRef/sharing_tools_and_toolboxes/pathnames_explained_colon_absolute_relative_unc_and_url.htm
java
if this helps, please rate
