Function like "Always Display Original Dialed Number" on CME?
Wyrwol666_2
Hi everyone,
the workers of my customer would like to use the "Called Number" directory on there IP phones. The problem is the prefix "0" isnt shown in this list (striped by translation rule), so its not possible to take a outgoing call this way.
The customer is using CME 8.1 on a UC520.
Is there a similar function like "Always Display Original Dialed Number" in CallManager Express? And how can I activate it? Alternatives?
Thanks for answers.
Rafael
paolo bevilacqua
Which type of lines to PSTN do you have ?
We use 2 ISDN lines.
Our problem is the striped trunk "0" in the phone dictonary "placed calls".
You should not need a translation-profile and rule when using POTS lines. For example:
dial-peer voice 123 pots
destination-pattern 0[1-9].......
port x/y/z
That will discard 0 and send the rest of number to telco.
Also, in most contries it is possible to eliminate the access digit altogether.
Try that and check again.
