FXO 4 Voice Ports always up (busy)
Vikrant Ambhore
We have UC520 with CME and a VIC2-4FXO, when someone try call to CME, always the signal is busy, on this moment there is no calls incomming to router,
In details:
If Someone make a call on Voice-port 0/1/1, Phone ringing on ext.206 If I pickup call on 206 that time All is going well but if doesn't pickup call on 206 then it forward to my mobile. But after Hang up running call, it's doesn't disconnect (As in a call comes in and is then not disconnected on completion) & I found both voice-port (Voice-port 0/1/0 ) & (Voice-port 0/1/1 ) is showing engaged(busy) & Off-hook.
it's showing off-hook until reset both voice ports
coinop-uc520#sh voice port summary
                                          IN       OUT
PORT           CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0          --  fxs-ls      up    dorm on-hook  idle     y
0/0/1          --  fxs-ls      up    dorm on-hook  idle     y
0/0/2          --  fxs-ls      up    dorm on-hook  idle     y
0/0/3          --  fxs-ls      up    dorm on-hook  idle     y
0/1/0          --  fxo-ls      up    dorm idle    off-hook  y
0/1/1          --  fxo-ls      up    dorm idle    off-hook  y
0/1/2          --  fxo-ls      up    dorm idle     on-hook  y
0/1/3          --  fxo-ls      up    dorm idle     on-hook  y
0/4/0          --  moh-imd     up    up   idle     seized   y
50/0/5         1      efxs     up    dorm on-hook  idle     y
50/0/5         2      efxs     up    dorm on-hook  idle     y
50/0/6         1      efxs     up    dorm on-hook  idle     y
50/0/6         2      efxs     up    dorm on-hook  idle     y
50/0/7         1      efxs     up    dorm on-hook  idle     y
50/0/7         2      efxs     up    dorm on-hook  idle     y
50/0/8         1      efxs     up    dorm on-hook  idle     y
50/0/8         2      efxs     up    dorm on-hook  idle     y
50/0/9         1      efxs     up    up   off-hook idle     y
50/0/10        1      efxs     up    up   on-hook  idle     y
50/0/10        2      efxs     up    up   on-hook  idle     y
50/0/11        1      efxs     up    dorm on-hook  idle     y
what can i do? please look on my config
voice-port 0/1/0
supervisory disconnect dualtone mid-call
no battery-reversal
output attenuation -6
cptone AU
timeouts call-disconnect 3
timeouts wait-release 3
timing sup-disconnect 300
connection plar opx 204
impedance complex1
caller-id enable
voice-port 0/1/1
no battery-reversal
cptone AU
connection plar opx 206
impedance complex1
caller-id enable
ephone-dn  13  dual-line
number 204 no-reg primary
label 204
description Lindsay Clark
name Lindsay Clark
call-forward busy 400
call-forward noan 400 timeout 10
ephone-dn  15  dual-line
number 206 no-reg primary
label 206
name Lindsay Clark
call-forward busy 202
call-forward noan 00411069447 timeout 10
5 Replies 5
David Trad
This is a common problem with analogue lines, it happens when you do either a transfer or call forward to an external number when you receive a call on the PSTN lines.
If a shut then no shut on the port does not bring it up then the only other option is to reload the system to clear the locked ports.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
ahmad_tamneh
Level 4
Level 4
There is a frequency used with the FXO port to allow it detect the Disconnect signal,
you need to find out what is the frequency then apply it on your voice port :
Ex for one of my FXO port :
voice class dualtone-detect-params 1
freq-max-deviation 25
freq-max-power 0
freq-min-power 13
freq-power-twist 4
cadence-variation 4
voice class custom-cptone JORDAN
dualtone disconnect
  frequency 415 425
  cadence 500 500
voice-port 0/3/1
supervisory disconnect dualtone pre-connect
supervisory custom-cptone JORDAN
supervisory dualtone-detect-params 1
input gain 14
compand-type a-law
cptone JO
timeouts interdigit 3
timeouts call-disconnect 2
timeouts ringing 5
timeouts wait-release 1
timing hookflash-out 500
connection plar opx 111299
Hi Ahmad,
How can we know these frequency values. Can you help
Location in Saudi Arabia
Ali
Hi Ali,
Well, as beginning you have to try using the cptone SA under the voice port , some times it work:
voice-port 0/3/1
cptone sa
if does not work, then you have to try record the disconnect tone then analyzes it to figure out the required frequency ... using special tools like "cool Edit"., this document attached "FXO port not getting disconnected."may show you how to do this process.
you have to find the accurate frequency to make sure it will work well.
you may see this link also: http://www.3amsystems.com/wireline/tone-search.htm?start=0&kCountry=11&kTone=10
it shows some predefied disconnect frequancy..
and as a final solution, if you have access or contact to some cisco employee they have powerful tool that analyzes  the frequency you may consult them.
if you want to send the file to cisco, I can tell you how to capture it .
best luck
D_Lebedev
Level 3
Level 3
Couple of times i have faced with similar problem.
In my cases,only workaround was install hardware busy tone detectors.
So i was not able to solve it with command like dualtone disconnect and etc...
Hope it helps...
