08-22-2017 07:41 AM - last edited on 03-25-2019 08:43 PM by ciscomoderator
HI all,
can anybody help to post a configuration of FXO voice port and E1 using only 8 channel
Note :- this project in Egypt .
08-22-2017 10:01 AM
Hi Hamada,
Which router model and protocol are you trying to use? Can you please exlain your scenario for use of E1 and FXO ports?
Vaijanath Sonvane
08-22-2017 10:12 AM
Vaijanath Sonvane,
It's 2911 will work as CME and want to configure the FXO and E1 for outging and incoming call
08-24-2017 07:41 PM
Hi Hamada,
Here is the attached configuration for FXO and E1 lines on CME Router. Please make sure to update :
1. Interface IP Address according to your setup
2. E1 line configuration (such as ISDN switch type, line coding, framing etc.) and E1 port number
3. FXO port numbers
4. Dial plan according to your country
Vaijanath S.
