FXO Caller-ID issue with Du UAE
wafikmaher
Faced an issue with the our Analog lines terminated on FXO ports. After long time working fine, the caller-ID stopped displaying for called incoming from the Analog lines on our Gateway conneted to Du telephone provider in Dubai Knowledge Village (Park). Debug vpm signal (attached) was showing the receiving the caller-id was failaing. After contacting the provider, i realized the they are using the ETSI standard, which doesnt match the "cptone AE", as shown from the debug its uses the american standard (BELLCORE). Adding the below commands to the voice-port fixed the issue:-
voice-port 0/0/0
  cptone DE
  caller-id alerting dsp-pre-allocate
  shut
  no shut
Then everything started working fine.
Current relecant Gateway config is also attached.
faiqmahdi
I wanted to take a moment to express my deepest gratitude for the solution you shared. I was struggling with it, and despite my best efforts, I couldn't find a resolution.  But your solution helped me to fix the issue.
voice-port 0/0/0
trunk-group FXO_Trunk
supervisory disconnect dualtone mid-call
pre-dial-delay 0
cptone AE
timeouts call-disconnect 1
timeouts ringing 45
timeouts wait-release 2
connection plar opx 401
caller-id enable
