FXO Caller ID
wilsonsant
Level 6
Level 6
Hi Guys,
Somebody knows say me if is possible to associate a Caller ID in a FXO port.
Thank You
paolo bevilacqua
Can't understand what do you mean. Can you make an example ?
thomuff
Level 3
Level 3
It is my understanding that you can't override the POTS line caller id. You could call your provider and have them change the caller id sent when using that line. We are changing all our POTS line to send out the main number as its caller id which is a DID on a PRI. Does this answer your question?
Please remember to rate!
