FXO card installation on MGCP gateway and CUCM 8.5 cionfiguration
midhun_km
Dears..
Good day...
I have MGCP gateway and recently added one 4 port FXO card -
I have one analog line with DID Number, i want configure the DID number on one of the existing phone.
How can i configure the CUCM and Gateway./ Steps....???
Cheeeeeeeeeerrrrss...!!!!!!!!!
Chris Deren
Are you an administrator of the system? These are pretty trivial, yet assume some knowledge of the system, so perhaps you may want to hire a professional?  However if you feel you can handle it, the high level steps are:
1. Configure the voice gateway with MGCP protocol
2. Build the Gateway in Communications Manager, define the port to point to internal extension via attendant field
3. Build a phone with that extension
Keep in mind an FXO port does not deliver DIDs, it is simply one number, just like a traditional home phone line.
HTH,
Chris
paolo bevilacqua
You should not use MGCP, especially with FXO, because that introduces significant configfuration complications and limitations.
You would use instead H.323 or SIP for a stable, feature-rich solution.
