Showing results forĀ
Search instead forĀ
Did you mean:Ā
FXO Configuration
allwyn.reuben
we have cisco 2900 series H323 router with CUCM 7.1.5 in our office. Also we have 5 Analog CO Trunks which are terminated in FXO ports.
These 5 CO Trunks are used as  backup incase the primary PRI failes. So that any ip phone can make/receive calls through this trunk. I have configured it. Can someone please check this and help how to configure properly. Im not receiving any calls through this FXO port.
Voice-port 0/1/0
trunk-group Lancaster
groundstart auto-tip
signal groundstart
input gain 12
connection plar opx immediate 7173977349
description 7173977349
caller-id enable
acampbell
May be a good idea to post your full config
For incoming calls from the PSTN you will need a voip dial peer
with a destination pattern that matches your PLAR number 7173977349
with the IP address of your CUCM.
This will also need to be a valid DN on your CUCM
Alex
Regards, Alex. Please rate useful posts.
