Walkthrough Wednesdays
432
Kent Drugge
Beginner
FXO Dial Access in Call Manager 11.5
I have a 2911 with an FXO port. I see this in Callmanager/devices/gateways. I see where to point an incoming call (Attendant DN). But I do not see or understand, how do I configure to dial the FXO port for outgoing from Callmanager?  Is this possible or must I configure the 2911 for Callmanager. Note this is for a single connection to a device, Not for outbound calling to the PSTN. Thank you,
6 REPLIES 6
Nipun Singh Raghav
Is this for MGCP ? FXO becomes an endpoint when configured with MGCP. The endpoint should appear on the RP if you don't have it as part of an RG already.
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Nipun,  Yes to your questions, MGCP and this FXO port is assigned in a route group. As I mentioned, I have used these for sites to have PSTN incoming lines ring the Attendant DN. But how about if I want to go OUT, like I wanted to make an outgoing phone call ?
Jaime Valencia
Hall of Fame Cisco Employee
Jaime Valencia
OK, you say "a device" and "not outbound calling to PSTN"
If you have a phone or a fax machine that you want to connect, you need an FXS, not an FXO.
java
if this helps, please rate
Kent Drugge
Beginner
Yes,  This is a trunk device and not a station device, Not FXS application. So if I can dial access the FXO and it opens the link to the device, then I send it DTMF similar to connecting with PSTN. But the question remains, How can I dial access an FXO port, so I can call it from an IP Phone on the system ?
Better to add the GW as H.323 or have a SIP trunk pointing to GW for this. DP on IOS should be able to route the call to FXO and trigger dial access.
Nipun Singh Raghav
Content for Community-Ad
Spotlight Awards 2021
