I have a 2911 with an FXO port. I see this in Callmanager/devices/gateways. I see where to point an incoming call (Attendant DN). But I do not see or understand, how do I configure to dial the FXO port for outgoing from Callmanager? Is this possible or must I configure the 2911 for Callmanager. Note this is for a single connection to a device, Not for outbound calling to the PSTN. Thank you,
Nipun, Yes to your questions, MGCP and this FXO port is assigned in a route group. As I mentioned, I have used these for sites to have PSTN incoming lines ring the Attendant DN. But how about if I want to go OUT, like I wanted to make an outgoing phone call ?
OK, you say "a device" and "not outbound calling to PSTN"
If you have a phone or a fax machine that you want to connect, you need an FXS, not an FXO.
Yes, This is a trunk device and not a station device, Not FXS application. So if I can dial access the FXO and it opens the link to the device, then I send it DTMF similar to connecting with PSTN. But the question remains, How can I dial access an FXO port, so I can call it from an IP Phone on the system ?
