08-26-2022 09:31 AM
hi I have a problem with a 2611XM router when I have an incoming call on the fxo the phone always rings even when the caller has cut down the call I have tried to give a configuration to the fxo in such a way as to cut down the incoming call.
voice-port 1/0/0
supervisory disconnect dualtone mid-call
cptone IT
timeouts call-disconnect 0
timeouts wait-release 1
connection plar 1010
impedance complex2
station-id name PSTN2
voice-port 1/0/1
no battery-reversal
cptone IT
connection plar 1011
impedance complex2
station-id name PSTN3
ho provato anche ha disabilitare la supervisory disconnect dual tone ed ho data anche il commando battery reversal ma nienta continua ha squillare il telefono ip come posso fare?
08-29-2022 06:02 AM
Try increasing the call-disc time
voice-port 1/0/0
timeouts call-disconnect 5
timeouts wait-release 5
09-07-2022 10:14 AM
I gave the commands but the problem persists, then I gave the command OPX connection opx plar and I solved the problem for the ip phones but I have a SPA-122 ATA and there I have a problem the analog phone connected to the spa122 is able to forward calls but he does not receive them.
