03-24-2016 04:25 AM - edited 03-17-2019 06:19 AM
Hi!
I have log from CME:
cme(config-voiceport)#do show voice call status
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0x7A1 22A0 0x70EC2724 0/0/2 No DSP 823 None 0/108
0x7A8 22A0 0x70CF0ABC 0/0/3 No DSP *823 None 108/0
0x94A 258C 0x70EC1CF8 0/0/1 0/1:1 5000 g711ulaw 100/5000
0x94F 2593 0x73310F7C 50/0/4.0 *A200A0000 g711ulaw 5000/20005
3 active calls found
What mean "No DSP"?
Best regards,
Kamil
03-24-2016 05:44 AM
Is the issue that you don't know what "No DSP" means, or is there something wrong with the way calls are handling? It may help to clarify what problem you're trying to resolve.
03-29-2016 11:22 AM
The conversation incoming to port 0/0/2 on Cisco CME to ephone-hunt 300, then to phone number 100 Cisco Phone. Phone 100 transfer incoming call to 877 (to Alcatel system) in mode full-blind. The call is transfer and appears "No DSP" 877. The conversation is transfered, but the port on Cisco is locked until manually do shutdown / no shutdown. What could be causing this?
cme#show voice call stat
0x36 129E 0x6837C2A4 0/0/2 0/1:1 A300A0100 g711ulaw 100/20010
0x37 12A2 0x73170C64 50/0/2.0 *A300A0100 g711ulaw 20010/100
1 active call found
0x36 129E 0x6837C2A4 0/0/2 0/1:1 877 g711ulaw 100/108
0x39 129E 0x681AA63C 0/0/3 0/1:2 *877 None 108/100
1 active call found
1 active call found
1 active call found
1 active call found
cme-#show voice call stat
0x36 129E 0x6837C2A4 0/0/2 No DSP 877 None 100/108
0x39 129E 0x681AA63C 0/0/3 No DSP *877 None 108/100
1 active call found
03-29-2016 02:40 PM
Also my config:
version 15.1
hostname cme
boot-start-marker
boot-end-marker
enable password xxx
aaa new-model
aaa session-id common
clock timezone GMT 1 0
ip source-route
ip cef
ip domain name xxx.uc
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
voice class dualtone-detect-params 1
freq-max-deviation 25
freq-max-power 0
freq-min-power 13
freq-power-twist 4
cadence-variation 4
voice class custom-cptone ALCATEL
dualtone disconnect
frequency 425
cadence 325 325
license udi pid CISCO3845-MB sn xxx
archive
log config
hidekeys
username xxx password 0 xxx
interface GigabitEthernet0/0
ip address 172.17.17.17 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 192.168.77.1 255.255.255.0
duplex auto
speed auto
media-type rj45
ip forward-protocol nd
no ip http server
control-plane
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone ALCATEL
supervisory dualtone-detect-params 1
input gain 14
compand-type a-law
timeouts call-disconnect 5
timeouts ringing 6
timeouts wait-release 5
connection plar 300
caller-id enable
voice-port 0/0/1
input gain 14
compand-type a-law
timeouts ringing 6
connection plar 300
caller-id enable
voice-port 0/0/2
input gain 14
compand-type a-law
timeouts ringing 6
connection plar 300
caller-id enable
voice-port 0/0/3
input gain 14
compand-type a-law
timeouts call-disconnect 1
timeouts ringing 6
timeouts wait-release 3
connection plar 100
caller-id enable
mgcp fax t38 ecm
mgcp profile default
dial-peer voice 100 pots
preference 1
destination-pattern 0.........
port 0/0/3
forward-digits all
dial-peer voice 108 pots
destination-pattern 8..
port 0/0/3
forward-digits all
dial-peer voice 104 pots
destination-pattern 7..
port 0/0/3
forward-digits all
gatekeeper
shutdown
telephony-service
em logout 0:0 0:0 0:0
max-ephones 4
max-dn 8
ip source-address 172.17.17.17 port 2000
system message CME
cnf-file location flash:
cnf-file perphone
user-locale 1 U1 PL
network-locale U1
time-zone 23
time-format 24
date-format dd-mm-yy
max-conferences 12 gain -6
hunt-group logout HLog
dn-webedit
time-webedit
transfer-system full-blind
transfer-pattern 7..
transfer-pattern 8..
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 10
softkeys idle Newcall Redial Pickup Cfwdall HLog Dnd
softkeys seized Endcall Redial Pickup Cfwdall HLog
softkeys connected Endcall Hold Trnsfer HLog
ephone-dn 1
number 100
pickup-group 10
description 100
name 100
ephone-dn 2
number 101
pickup-group 10
description 101
name 101
ephone-dn 3
number 102
pickup-group 10
description 102
name 102
ephone-dn 4
number 103
pickup-group 10
description 103
name 103
ephone 1
mac-address 3C0E.236C.5A5A
type 7945
button 1:1
ephone 2
mac-address 189C.5D21.9A50
type 7945
button 1:2
ephone 3
mac-address 3C0E.236D.B920
type 7945
button 1:3
ephone 4
mac-address 3C0E.236D.CD43
type 7945
button 1:4
ephone-hunt 2 sequential
pilot 300
list 101, 102, 100, 103
timeout 15, 15, 15, 15
line con 0
line aux 0
line vty 0 4
scheduler allocate 20000 1000
ntp master
end
