12-09-2015 12:41 PM - edited 03-17-2019 05:10 AM
I'm testing FXO ports on a newly installed router.
If I disconnect a trunk to simulate a failed trunk, outgoing calls don’t hunt to the next trunk.
I have all four ports in the same trunk group with no priority in Round-Robin.
What do I need to configure to make it hunt past the failed or disconnected trunk?
Thanks in advance,
Ray
Solved! Go to Solution.
12-10-2015 12:33 AM
Hi Ray,
Please check the following post for similar query
https://supportforums.cisco.com/discussion/12056631/need-sample-cme-multiple-fxo-ports-hunt-fashion
Manish
12-10-2015 12:33 AM
Hi Ray,
Manish
12-10-2015 07:12 AM
Thanks Manish!!!
That helped.
