Walkthrough Wednesdays
1432
Highlighted
Participant
FXO Incoming / Outgoing Setup for 911
I have Analog FXO cards in each gateway for incoming / outgoing 911 calls only (all other calls are routed to PRI).
Outbound calls are working for 911, but if the 911 operator has to call the site back; they receive a fast busy when they call the number attached to the FXO port.
I'd like to be able to send these incoming calls to a specific extension. Here is the config:
trunk group  OUTBOUND-SRST
hunt-scheme sequential
voice-card 0
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.610
description DATA NETWORK
encapsulation dot1Q 610
ip address 10.10.6.1 255.255.255.0
interface FastEthernet0/0.619
description VOICE NETWORK
encapsulation dot1Q 619
ip address 192.168.6.1 255.255.255.0
h323-gateway voip bind srcaddr 192.168.6.1
interface FastEthernet0/1
description UPLINK to FBDO
  duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 10.1.1.1
no ip http server
no ip http secure-server
ip access-list standard SNMP
permit 10.1.200.63
snmp-server community 3C4a5I6S7p8 RO SNMP
control-plane
voice-port 0/0/0
timing hookflash-out 50
voice-port 0/0/1
trunk-group OUTBOUND-SRST 1
voice-port 0/0/2
voice-port 0/0/3
ccm-manager fallback-mgcp
ccm-manager redundant-host 192.168.10.20
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 192.168.111.20
ccm-manager config
mgcp
mgcp call-agent 192.168.111.20 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0.619
mgcp bind media source-interface FastEthernet0/0.619
mgcp profile default
dial-peer voice 999000 pots
service mgcpapp
port 0/0/0
dial-peer voice 1 pots
trunkgroup OUTBOUND-SRST
destination-pattern 9[2-9]......
forward-digits 7
dial-peer voice 911 pots
destination-pattern 9911
port 0/0/0
forward-digits 3
prefix 911
dial-peer voice 2 pots
destination-pattern 91[2-9]..[2-9]......
forward-digits 11
dial-peer voice 3 pots
destination-pattern 918[8,7,0,6][8,7,0,6].......
forward-digits 11
dial-peer voice 4 pots
destination-pattern 9[2-8]11
forward-digits 3
dial-peer voice 5 pots
destination-pattern 90[2-9]..[2-9]......
forward-digits 11
dial-peer voice 6 pots
destination-pattern 9011T
forward-digits all
prefix 011
dial-peer voice 999001 pots
service mgcpapp
port 0/0/1
4 REPLIES 4
Highlighted
Participant
Anyone?
Highlighted
Have you configured the attendant dn on the gateway config page in CUCM?
Highlighted
So a bit confused on your situation. Do all inbound calls come into the FXO port? If so are any inbound calls working to the number you have on caller-id? Since you are using MGCP looking at the config on the GW will not give us any indication as to what you have configured for this port. It could be as simple as Don suggested that there is no attendent dn on the GW config page. Or you are masking the caller-id with a wrong number for 911 calls.
Could you run make a call to the number which you are sending out to 911 and run 'debug voice cc inout' on the GW?
Might give us a clearer picture what is happening here.
Highlighted
Thanks everyone - for some reason I didn't have a CSS setup on the port in CUCM.
All good now!
Content for Community-Ad
