I have the following configuration cisco 2811 H.323 gateway with release 10.5.2 of CUCM/CUC having FXO line.
If someone receive incoming call from PSTN then line remains busy after calling party disconnect the call and end user remains getting disconnect tune.
voice-port 0/3/0
translation-profile incoming from-PSTN
input gain 14
compand-type a-law
no comfort-noise
cptone AE
timeouts call-disconnect 0
timeouts ringing 30
timeouts wait-release 1
connection plar opx 525
caller-id enable
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
forward-digits all
dial-peer voice 9 pots
description ==PSTN==
destination-pattern .T
port 0/3/0
dial-peer voice 100 voip
description ==DP for 1xx==
service session
destination-pattern 1..
session target ipv4:10.172.192.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 555 voip
service session
destination-pattern 525
codec g711ulaw
no vad
if i add "supervisory disconnect anytone" under voice-port then issue resolves but incoming calls disconnect after 1 or 2 seconds.
please advise what to do to fix the issue. thank you
