What are the options for FXO these days? We have a need to connect 4 POTS lines to the FXO port. We do not want to use any 2900 or 3900 series routers.
You can use an ISR 4K with FXO card, or a VG310 or VG320 with an FXO card
java
if this helps, please rate
