FXO Outbound Call Failure
Ruslan Amrahov
Hi there,
I have H323 gateway with FXO card, When I am making a call from CCM to PSTN through certain port number, call gets out but I hear call cancelation beeps.  When I connect analog phone to this line I can make the calls successfully.
what could be a problem?
17 Replies 17
Chris Deren
Are you sure this is an FXO port and not FXS?  Not sure how analog phone would work when connected to FXO port.
Chris
moataz_mamdouh
Hello
I saw from your debug the outgoing dial-peer is 110 and the inbound is 1001
from the ccapi the called number is 110493 , are you sure this is a PSTN number ?
can you paste the configuration and of both dial peers and make sure of the dialed numbers
Moataz Tolba
Sorry guys, I guess I was not clear enough. The scenario is as follows: I have 2901 gateway with FXO ports and CCM with IPPhones using it as H323 gateway. There is another analog PBX which I connect my voice gateway via FXO to. The remote PBX has internal dial-plan with numbers 49X. I am using 110493 as a destination pattern to designate the sertain FXO port for the sertain IPPhone. So, when the caller with extension 110 calls 9.493 with predot dropping, CCM sends 493 with 110 added as prefix. After, due to 110 being a pots dial-peer, it stripts the digits and sends only wildcard, which is 493. The call goes through successfully but drops after 2-3 ringouts and I hear only beep-beep-beeeeeeep, beep-beep-beeeeeeep, something like that . But, when I connect the usual analog phones to the lines which comes from that remote PBX and dial the same 493 number, the call succeeds. I hope I was a little bit clear now
Thanks for clarification
have you tried playing with those relalated to supervisory disconnect and timers , the battery reversal and all these stuff
Moataz
Thank you for your answer, Moataz
Could you be more specific? I tried to turn battery reversal on and off, played a little with timers, no help.
it seems also you are having a problem in caller ID
can you try this
caller-id alerting dsp-pre-alloc
Moataz,
CallerID is not critical for this case, but anyway i have only caller-id alerting ring option. The main problem is that calls do not get through at all. It's the first time I get the problem such this. Did you get which tones I am getting? they are high, can not find them on the web
Can you post your H323 router config
Alex
Regards, Alex. Please rate useful posts.
try to change the cptone
CPTone is the bad-bad thing, the reason why callerid is not working. TELKO workers do not know cptone used. I found that RU is used, but not on all ports. You think cptote could be resolution to callerid or calling out issue?
Alex,
see the config in attachment. Here, 0/1/1 is mainly used to test. Now it's running via MGCP, but i was testing it using H323, same thing.
Here are the H323 dial peers from your config.
I do not see any peer that would match 110... to
all say 493 to be sent to a FXO port
dial-peer voice 1001 voip
preference 1
destination-pattern ...
session target ipv4:10.10.1.11
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 1002 voip
preference 2
session target ipv4:10.10.1.12
codec g711ulaw
no vad
dial-peer voice 131 pots
service mgcpapp
port 0/1/1
dial-peer voice 116 pots
destination-pattern 116...
port 0/1/2
dial-peer voice 130 pots
destination-pattern 130...
port 0/1/0
dial-peer voice 491 pots
destination-pattern 491...
port 0/1/3
dial-peer voice 58 pots
destination-pattern 58T
port 0/2/3
So 110 will be matchinf your VOIP dial peer
1001 or 1002 and trying to send the call back to the CUCM
You need to create a dial peer like this
dial-peer voice 110 pots
desc *** TO OTHER PBX **
destination-pattern 110...
port a/b/c (The correct FXO)
Alex
Sorry, I was trying to use this port as MGCP endpoint. It was just the same as you typed but the result was the same.
If you are using the MGCP you will need to strip the 110 before the call
is sent to the gateway port.
In your post you say the user dials
9.493
So just create a route pattern to match this 9.493 string.
Drop the preDOT (9) in the CALLED PARTY TRANSFORMATION on the route pattern
This will send the 493 to the MGCP FXO port
Alex
Alex, than you, but the issue is not in call routing and digit manipulation. I do it as you wrote and call successfully goes through the port, but after 3 rings it says bee-bee-beeeeo I connected FixedGSM device right now to this port and successfully called to my mobile number.
