FXO outgoing call failes in MGCP with CUCM
Amit23
Level 4
Level 4
Hi ,
i ahve cucm 10 with mgcp gateway 3925...
it has 4 port fxo card..in which analog line is connected...
incoming to line is ok..but wen dialing outside with line, it gives silence in begin and then busy tone and disconnect it..
what could be issue...?
see attached logs and router config..
Warm Regard's
Amit Sahrma
2 Accepted Solutions
1- Can you check the below:-
mgcp dtm-relay voip codec all mode out
no mgcp
mgcp
2-Kindly check the RP which is responsible correctly ."check the number of digits , predot to discard 9 , RL" .
please rate all useful infromation
Hello
i checked the logs and found the below:-
FXOGS_WAIT_TIP_GROUND
Kindly change the port to LS "Loop start" and test again.
Please rate all useful information
22 Replies 22
islam.kamal
Level 10
Level 10
Can you add the below:-
mgcp bind media source-interface gig 0/0
mgcp bind control source-interface gig 0/0
no mgcp
mgcp
Then test again
thanks
please rate all useful information
would be this affect the call flow?
Warm Regard's
Amit Sahrma
Yes , this will solve your issue. You have to bind the source interface for signalling and media packets.Test and check please.
checked...but it have same issue...
Warm Regard's
Amit Sahrma
no mgcp
mgcp
checked and apply this command..
but issue same...
Warm Regard's
Amit Sahrma
Hello
let me change and test it..
Warm Regard's
Amit Sahrma
thanks !
it is working now...
Warm Regard's
Amit Sahrma
thanks islam...
but i have issue..on FXO port...
when calls coming inside...it shows unknown call...
how can see the caller details on phone?
Warm Regard's
Amit Sahrma
Hello
Thanks so much for your rating , and i am so happy that your issue solved. Look i am sorry for the delay because i have to check the config before debugs. Anyway can you do a new debug " debug ccapi inout" for incoming call .Keep your mid there all two possible cases for the problem
1- ITSP not send called id and this will check by debug after you will send.
2-Problem for MGCP , MGCP has a big problem to display caller id and most preferred solution is H323 with FXO.
please rate all useful ifnromation
thanks for your help!
but how can remove 5 second silence that coming when dialing outside call?
Warm Regard's
Amit Sahrma
To remove 5 sec
voice-port x/x/x
no timeouts wait-release 5
sh
no sh
Please rate all useful infromation
HI
Timeouts wait-release is the amount of time that the FXO takes before the system starts the process for releasing voice  ports after a failed call.
