fxo port dead air
Joli Martinez
The carrier is delivering an analog port to an IAD.  The IAD is supposed to send it to an IPPBX.  When I call the number it appears the call is picked up and all I get is dead air.  The call never goes to the PBX. I have changed the dial-peers to .T to make sure they match.  I will change them to a more precise match once I figure out what is going on.
voice-port 0/0
 connection plar 1000
 caller-id enable
dial-peer voice 100 pots
 description Incoming Called number X
 incoming called-number .T
 direct-inward-dial
 port 0/0
dial-peer voice 1000 voip
 destination-pattern .T
 session target ipv4:10.41.100.2
*Mar 15 02:14:42.568: htsp_process_event: [0/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
*Mar 15 02:14:42.568: htsp_timer - 125 msec
*Mar 15 02:14:42.696: htsp_process_event: [0/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
*Mar 15 02:14:42.696: htsp_timer - 10000 msec
*Mar 15 02:14:42.696: htsp_timer3 - 5600 msec
*Mar 15 02:14:42.696: [0/0] htsp_start_caller_id_rx:BELLCORE
*Mar 15 02:14:42.696: htsp_start_caller_id_rx create dsp_stream_manager
*Mar 15 02:14:42.696: [0/0] htsp_dsm_create_success  returns 1
*Mar 15 02:14:44.792: htsp_process_event: [0/0, FXOLS_RINGING, E_DSP_SIG_0100]
*Mar 15 02:14:44.792: fxols_ringing_not
*Mar 15 02:14:44.792: htsp_timer_stop
*Mar 15 02:14:44.792: htsp_timer - 10000 msec
*Mar 15 02:14:45.888: [0/0] htsp_dsm_feature_notify_cb  returns 2 id=DSM_FEATURE_SM_CALLERID_RX
*Mar 15 02:14:45.888: htsp_process_event: [0/0, FXOLS_RINGING, E_HTSP_CALLERID_RX_DONE]
*Mar 15 02:14:45.888: htsp_timer_stop
*Mar 15 02:14:45.888: htsp_timer_stop3
*Mar 15 02:14:45.888: [0/0] htsp_stop_caller_id_rx. message length 40htsp_setup_ind
*Mar 15 02:14:45.888: [0/0] get_fxo_caller_id:Caller ID received. Message type=128 length=40 checksum=D7
*Mar 15 02:14:45.888: [0/0] Caller ID String 80 25 02 0B 31 36 37 38 33 39 31 36 36 37 36 01 08 30 33 32 36 31 36 30 36 07 0C 2B 31 36 37 38 33 39 31 36 36 37 36 D7
*Mar 15 02:14:45.892: [0/0] get_fxo_caller_id calling num=1333444555 calling name=+13334445555calling time=03/26 16:06
*Mar 15 02:14:45.892: fxols_callerid_done: call being answered
*Mar 15 02:14:45.900: htsp_process_event: [0/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
*Mar 15 02:14:45.900: fxols_wait_setup_ack:
*Mar 15 02:14:45.900: [0/0] set signal state = 0xC timestamp = 0fxols_check_auto_call
*Mar 15 02:14:45.912: htsp_process_event: [0/0, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
*Mar 15 02:14:45.912: htsp_timer - 120000 msec
*Mar 15 02:14:45.916: [0/0] htsp_dsm_close_done
0 Replies 0
