Walkthrough Wednesdays
4061
Highlighted
FXO port issue
Dear all,
Am using cisco 2921 CME 8.6 with ios version c2900-universalk9-mz.SPA.151-4.M4.bin..
Also am using a dedicated one fxo port for a specific user to send and receive calls,, the user always faces busy tone when initiate outgoing call, the fxo port doesnt disconnect from the previous call.
voice-port 0/3/2
supervisory disconnect dualtone mid-call
no battery-reversal
cptone SA
timeouts interdigit 3
timeouts call-disconnect 1
timeouts wait-release 1
connection plar opx immediate 4015
impedance complex2
caller-id enable
Any Idea to solve the issue, please???
#sh voice port 0/3/2
Foreign Exchange Office 0/3/2 Slot is 0, Sub-unit is 3, Port is 2
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is plar opx
Connection Number is 4015
Initial Time Out is set to 15 s
Interdigit Time Out is set to 3 s
Call Disconnect Time Out is set to 1 s
Power Denial Disconnect Time Out is set to 1000 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 1 s
Companding Type is u-law
Region Tone is set for SA
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to complex2 Ohm
Station name None, Station number None
Caller ID Info Follows:
Standard BELLCORE
Caller ID is received after 1 ring(s)
Translation profile (Incoming):
Translation profile (Outgoing):
lpcor (Incoming):
lpcor (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Battery-Reversal is disabled
Number Of Rings is set to 1
Supervisory Disconnect is dualtone mid-call
Answer Supervision is inactive
Hook Status is On Hook
Ring Detect Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Dial Out Type is dtmf
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Percent Break of Pulse is 65 percent
GuardOut timer is 2000 ms
Minimum ring duration timer is 125 ms
Hookflash-in Timing is set to 600 ms
Hookflash-out Timing is set to 400 ms
Supervisory Disconnect Timing (loopStart only) is set to 350 ms
OPX Ring Wait Timing is set to 6000 ms
Secondary dialtone is disabled
23 REPLIES 23
Highlighted
Advocate
HI Mohammed
Look in this Link there some information that can help you to tshoot this case.
Cheers
Bruno Rangel
"Se você quiser alguém em quem confiar, confie em si mesmo. Quem acredita sempre alcança"
Renato Russo
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
Highlighted
Hi Mohammad,
Is it newly implemented??
Can you send me the configuration of your gateway and how many FXO ports you are using???
Have you checked it by doing shut and no shut to the specific FXO port??
Vatandeep Singh
Kindly rate if the contents is helpful.
Highlighted
Thanks Sinqh and sorry for being late,
yes i tried to do shut and no shut, but later the issue returns again,
am using 2 FXO cards, i notice today that the dedicated port and other fxo ports remains off-hook status when i do sh voice port summ despite the user hangs up phone,, when the user try to dial another call, he receive a busy tone.
how i can solve the issue of fxo ports keeping in off-hook status after user hangs up the phone??
thanks
Highlighted
Beginner
Hi Mohammad,
let try:
CIPC (softphone on PC)------CME(FXO)-------PSTN Network
Start wireshark and capturing,then make call from CIPC to PSTN network, let far side (PSTN) hang up first, until CIPC hears 'tut tut'...
Use wireshark to capture the packet from CME to CIPC (filter UDP packet between CME and IPCP).
Then upload .pcap file here, I hope I can support
Highlighted
thanks lan for your help,,
i cant use the cipc for the current time, but i noticed today
thanks
Highlighted
Hi Mohammed,
Can you please share all voice-port sh run.
Thanks!!!
Vatandeep Singh
Highlighted
here are they:
0/3/0 and 0/3/2 are dedicated ports to Users, 4446 is the autoattendent.
voice-port 0/2/0
trunk-group 2
no battery-reversal
cptone SA
connection plar opx immediate 4446
impedance complex2
caller-id enable
voice-port 0/2/1
trunk-group 2
no battery-reversal
cptone SA
impedance complex2
caller-id enable
voice-port 0/2/2
trunk-group 2
no battery-reversal
cptone SA
impedance complex2
caller-id enable
voice-port 0/2/3
trunk-group 2
no battery-reversal
cptone SA
impedance complex2
caller-id enable
voice-port 0/3/0
no battery-reversal
cptone SA
connection plar opx immediate 4001
impedance complex2
caller-id enable
voice-port 0/3/1
trunk-group 2
no battery-reversal
cptone SA
impedance complex2
caller-id enable
voice-port 0/3/2
no battery-reversal
cptone SA
impedance complex2
caller-id enable
voice-port 0/3/3
trunk-group 2
no battery-reversal
cptone SA
impedance complex2
caller-id enable
Highlighted
"after user hangs up the phone" --> User is far side (PSTN) or IP Phone side??
Highlighted
after the user hangs up the phone, the user of the ip phone when initiate to dial another call , he receive a busy tone.
when i do sh voice port summ, the fxo port still shows off-hook status.
regards
Highlighted
Hall of Fame Master
Are you doing call-forward from one FXO port to another ?
Highlighted
No Mr. Paolo,
there are two users whom having dedicated ports for them for dialing and recieving calls as you can see above.
ports are 0/3/0 and 0/3/2.
i keep solve this issue temprory by doing shut and no shut....
any ideas.
thanks.
Highlighted
Hi Mohammed
After the near-end user (using IP Phone) hung up the call and before he initiates a new call, please "show voice call status"
Besides,let make a test call (ex: through port 0/3/0)  and "debug vpm signal " and "debug vpm port 0/3/0" . After finish the test call, please get back with "show" and "debug" log
Highlighted
Update IOS. When an IP phone hangs up, the voice port must hang up as well.
Highlighted
Hi Paolo,
Not the ip phone which hangs up, the fxo port is the one which hangs and shows the yellow color from back of the router on the fxo port....
it is solved temprory when i switch off the router, then unplug and plug the fxo port,,,
If you dont mind,please i want an answer from you with yes or No in another matter,,,,
do the cisco CME support a voice calling solution that can be used to make a voice call thru Mics and external speakers which is is similar to hospital systems where they call thru external speakers for any doctor to attend the operation room???????
Content for Community-Ad
