FXO port line voltage issue with parallel lines
Hilal Computers
Beginner
Beginner
Hi All,
I have a situation where , six analog lines connected to the cme. PSTN lines acts as one main line and rest of the five lines are as parallel lines to the main line.
Now the issue is , i can get the ring vlotage in the main line, output below;
#test voice port 0/0/0 si-reg-read 29 1
VOICE_ROUTER_NBN#
May  3 09:42:36.511:
Values read from SiLabs Codec connected to DSP 0, channel 0:
Register 29 = 0x33
When i test the other five lines, those lines don't have any ring voltage at all..
VOICE_ROUTER_NBN#test voice port 0/0/2 si-reg-read 29 1
VOICE_ROUTER_NBN#
May  3 09:41:27.263:
Values read from SiLabs Codec connected to DSP 0, channel 2:
Register 29 = 0x00
I have teseted the all six analog lines from the POTS phone (Analog phone). all are working fine.
Now my question is how to make these other lines work (or get the ring voltage from fxo port) ?? currently i can make outgoing calls only through the main line (First Line).
Expecting a positive responce from someone
kajen
Router doesn not detect loop current. That cannot be fixed from router side.
Even if you have loop current with regular phone, telco needs to fix it. You can tell them that you need higher current or voltage on the loop.
Please remove duplicate posts.
7 Replies 7
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Which IOS version are you using?
csan you post "debug vpm signal" when calling out ?
Hi Paolo,
IOS version is Version 15.0(1r)M15.......check the out put below,
VOICE_ROUTER_NBN#debug vpm signal
Voice Port Module signaling debugging is enabled
VOICE_ROUTER_NBN#
May  3 10:22:50.619: htsp_process_event: [50/0/21.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
May  3 10:22:50.619: [50/0/21.1] get_local_station_id calling num=131 calling name=EXT 131 calling time=05/03 13:22  orig called=
May  3 10:22:50.623: htsp_process_event: [50/0/21.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
May  3 10:22:51.291: htsp_digit_ready(50/0/21.1): digit = 9
May  3 10:22:51.627: htsp_digit_ready(50/0/21.1): digit = 3
May  3 10:22:51.811: htsp_digit_ready(50/0/21.1): digit = 6
May  3 10:22:52.159: htsp_digit_ready(50/0/21.1): digit = 5
May  3 10:22:52.311: htsp_digit_ready(50/0/21.1): digit = 5
May  3 10:22:52.627: htsp_digit_ready(50/0/21.1): digit = 8
May  3 10:22:52.827: htsp_digit_ready(50/0/21.1): digit = 5
May  3 10:22:53.055: htsp_digit_ready(50/0/21.1): digit = 2
May  3 10:22:53.243: htsp_digit_ready(50/0/21.1): digit = 1
May  3 10:22:53.247: htsp_timer_stop3
May  3 10:22:53.247: htsp_process_event: [50/0/21.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
May  3 10:22:53.247: [50/0/21.1] set signal state = 0x8 timestamp = 0htsp_setup_req
May  3 10:22:53.247: htsp_process_event: [0/0/1, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
May  3 10:22:53.247: [0/0/1] set signal state = 0xC timestamp = 0
May  3 10:22:53.247: htsp_timer - 1300 msec
May  3 10:22:53.503: htsp_process_event: [0/0/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
May  3 10:22:53.503: htsp_timer2 - 1000 msec
May  3 10:22:53.503: htsp_timer_stop
May  3 10:22:54.503: htsp_process_event: [0/0/1, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
May  3 10:22:54.503: htsp_timer_stop
May  3 10:22:54.503: htsp_timer_stop2
May  3 10:22:54.503: [0/0/1] set signal state = 0x4 timestamp = 0
May  3 10:22:54.503: htsp_process_event: [0/0/1, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
May  3 10:22:54.503: htsp_timer_stop3 htsp_setup_req
May  3 10:22:54.503: htsp_process_event: [0/0/2, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
May  3 10:22:54.503: [0/0/2] set signal state = 0xC timestamp = 0
May  3 10:22:54.503: htsp_timer - 1300 msec
May  3 10:22:54.759: htsp_process_event: [0/0/2, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
May  3 10:22:54.759: htsp_timer2 - 1000 msec
May  3 10:22:54.759: htsp_timer_stop
May  3 10:22:55.759: htsp_process_event: [0/0/2, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
May  3 10:22:55.759: htsp_timer_stop
May  3 10:22:55.759: htsp_timer_stop2
May  3 10:22:55.759: [0/0/2] set signal state = 0x4 timestamp = 0
May  3 10:22:55.759: htsp_process_event: [0/0/2, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
May  3 10:22:55.759: htsp_timer_stop3 htsp_setup_req
May  3 10:22:55.759: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
May  3 10:22:55.759: [0/0/3] set signal state = 0xC timestamp = 0
May  3 10:22:55.759: htsp_timer - 1300 msec
May  3 10:22:56.015: htsp_process_event: [0/0/3, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
May  3 10:22:56.015: htsp_timer2 - 1000 msec
May  3 10:22:56.015: htsp_timer_stop
May  3 10:22:57.015: htsp_process_event: [0/0/3, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
May  3 10:22:57.015: htsp_timer_stop
May  3 10:22:57.015: htsp_timer_stop2
May  3 10:22:57.015: [0/0/3] set signal state = 0x4 timestamp = 0
May  3 10:22:57.015: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
May  3 10:22:57.015: htsp_timer_stop3 htsp_setup_req
May  3 10:22:57.015: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
May  3 10:22:57.015: [0/1/0] set signal state = 0xC timestamp = 0
May  3 10:22:57.015: htsp_timer - 1300 msec
May  3 10:22:57.271: htsp_process_event: [0/1/0, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
May  3 10:22:57.271: htsp_timer2 - 1000 msec
May  3 10:22:57.271: htsp_timer_stop
May  3 10:22:58.271: htsp_process_event: [0/1/0, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
May  3 10:22:58.271: htsp_timer_stop
May  3 10:22:58.271: htsp_timer_stop2
May  3 10:22:58.271: [0/1/0] set signal state = 0x4 timestamp = 0
May  3 10:22:58.271: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
May  3 10:22:58.271: htsp_timer_stop3 htsp_setup_req
May  3 10:22:58.271: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
May  3 10:22:58.271: [0/1/1] set signal state = 0xC timestamp = 0
May  3 10:22:58.271: htsp_timer - 1300 msec
May  3 10:22:58.527: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
May  3 10:22:58.527: htsp_timer2 - 1000 msec
May  3 10:22:58.527: htsp_timer_stop
May  3 10:22:59.527: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
May  3 10:22:59.527: htsp_timer_stop
May  3 10:22:59.527: htsp_timer_stop2
May  3 10:22:59.527: [0/1/1] set signal state = 0x4 timestamp = 0
May  3 10:22:59.527: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
May  3 10:23:01.699: htsp_process_event: [50/0/21.1, EFXS_OFFHOOK, E_DSP_SIG_0100]efxs_offhook_onhook
May  3 10:23:01.699: htsp_timer - 10 msec
May  3 10:23:01.711: htsp_process_event: [50/0/21.1, EFXS_OFFHOOK, E_HTSP_EVENT_TIMER]efxs_offhook_timer
May  3 10:23:01.711: htsp_process_event: [50/0/21.1, EFXS_ONHOOK, E_HTSP_RELEASE_REQ]efxs_onhook_release
May  3 10:23:01.711: htsp_timer_stop
May  3 10:23:01.711: [50/0/21.1] set signal state = 0x4 timestamp = 0
kajen
That is ROMMON version, not IOS, check again.
Also please remove duplicate post.
sorry,
c2900-universalk9-mz.SPA.151-4.M3.bin
Thank you for your reply Paolo.. Finally telco came and fixed it for us.
Thanks for the nice rating and good luck!
Recognize Your Peers
