10-16-2012 11:15 PM - edited 03-16-2019 01:43 PM
Hello everybody
i have 12 fxo ports which connect to PSTN with my 2801 router and PVDM2-16
and i have CUCM7.1 which is my Call Processing server
my problem is somtimes oitgoing calls through FXOs have problem, for example they have echo, delay and a major problem is both side of the phone line could not speak at same time and call getting beaked until one side stop talking.
does anybody have any of this problem
here is my FXO ports config
voice-port 0/0/0
trunk-group FXOPORTS
supervisory disconnect dualtone pre-connect
supervisory answer dualtone
input gain 14
timeouts call-disconnect 0
timeouts wait-release 1
connection plar opx 899
caller-id enable
and i 'm also test with this config too:
voice-port 0/0/1
connection plar 700
caller-id enable
10-17-2012 02:58 AM
Try removing the 'input gain 14', resetting the voice port (shutdown, no shutdown) and see if the issue improves.
More detail:
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080149a1f.shtml
Please remember to rate helpful responses and identify helpful or correct answers.
10-17-2012 08:25 AM
Dear Jonathan
thank for your replay
actually i'm already test this, but its not help
today i'm thinking about the change the signaling from Loopstart to Ground Start, whats your opinion?? is it useful or no?
10-17-2012 02:38 PM
No, with groundstart it would not work at all.
You should configure cptone
10-20-2012 12:17 PM
Dear Paolo
how can i capture my CPTON to correct one, i know i can use cptone command under line and use predefined options
10-20-2012 01:20 PM
There are a number of predefined countrys for CPTONE. In what country do you have the system deployed?
10-20-2012 01:26 PM
You should configure the Call Progress Tones to match your Central office or ISP, try under Voice-port configuration mode you can do the follows:
MYLABVGW(config-voiceport)#cptone ?
locale 2 letter ISO-3166 country code
AR Argentina IN India PE Peru
AU Australia ID Indonesia PH Philippines
AT Austria IE Ireland PL Poland
BE Belgium IL Israel PT Portugal
BR Brazil IT Italy RU Russian Federation
CA Canada JP Japan SA Saudi Arabia
CN China JO Jordan SG Singapore
CO Colombia KE Kenya SK Slovakia
C1 Custom1 KR Korea Republic SI Slovenia
C2 Custom2 KW Kuwait ZA South Africa
CY Cyprus LB Lebanon ES Spain
CZ Czech Republic LU Luxembourg SE Sweden
DK Denmark MY Malaysia CH Switzerland
EG Egypt MX Mexico TW Taiwan
FI Finland NP Nepal TH Thailand
FR France NL Netherlands TR Turkey
DE Germany NZ New Zealand AE United Arab Emirates
GH Ghana NG Nigeria GB United Kingdom
GR Greece NO Norway US United States
HK Hong Kong OM Oman VE Venezuela
HU Hungary PK Pakistan ZW Zimbabwe
IS Iceland PA Panama
From the list you can choose the 2 letter that corresponds your Country or Region
