FXO ports stuck in off-hook state!
asbesi001
We have a situation where fxo ports stuck in off-hook state. I have to do a shut /no shut in order for fxo ports to come back to normal. The same situation occurs after 24h up to 48h. We have CME 7.1 on Cisco 2811 Router and below is the fxo port configuration:
voice-port 0/0/1
  trunk-group FXO_GROUP 10
  translation-profile incoming PREFIX_0
  supervisory disconnect anytone
  timeouts initial 0
  timeouts interdigit 0
  connection plar opx 8100
  caller-id enable
voice-port 0/0/2
  trunk-group FXO_GROUP 6
  timeouts initial 0
  timeouts call-disconnect 3
  timeouts wait-release 3
  caller-id enable
voice-port 0/0/3
  trunk-group FXO_GROUP 8
  timeouts initial 0
  caller-id enable
I have put timeouts call-disconnect 3 and timeouts wait-release 3 under port 0/2, just to see if that can fix the issue, but no success.
Any idea how can we fix this issue?
Thank you.
5 Replies 5
paolo bevilacqua
That is normal when you use AA or similar, search documention or forum for "disconnect supervision". There are many threads about.
Note, you should also update you IOS that is very old.
How do you mean 'this is normal', this situation did not happen before, even with this version of CME.
Do you have any suggestion that can help solve the problem?
Thank you.
Again, you van use the search function for the many similar threads.
Yes, I already did that before asking for help on the forum.
thanks anyway
Looks to me you may have searched, but not understood the root of the problem. Unless you are the US or other country that removes power to indicated remote disconnect, you need to configure the exact tones disconnect tones for your country. Anytone will not work.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Or find what has been changed when the problems started occurring , eg, AA, call transfer FXO-to-FXO, etc.
