FXO PSTN Disconnection
lachlanpeters
Frequent Visitor
Frequent Visitor
We are currenlty having a problem with 2821 with a 4fxo not tell the PSTN ( Telstra ) that the call has end.
     IP Phone <--- 2821 <---PSTN<---- Phone B
          If the IP Phone hungup first, on a PSTN originated call, the PSTN network will not see the hangup. If you listen to the phone line the call is still           active and connected to phone b.
     IP Phone ---> 2821 ---> PSTN----> Phone B
     But if it is a IP Phone originated call the hungup works ok.
The 2821 is config with mgcp.
I have looked at
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
But we are still having problems.
eg config
voice-port 0/2/2
trunk-group VOICE-T
echo-cancel coverage 64
cptone AU
timing hookflash-out 50
impedance complex1
5 Replies 5
paolo bevilacqua
You need to configure the exact tome params as a custom. cptone alone won't work.
I have try some off -
https://supportforums.cisco.com/message/1166213#1166213
Is there a resource to ffind the correct one?
Yes resources and methods are discussed in the many many threads on the subject, if you could take the time to search.
I have been searching and reading threads for the last 8 days. I was thinking that I would finely start a thread to get some specifics help. Thankyou for the help
So if you have searched, you should have found:
1. recoding tones and frequency analysys detailed discussions.
2. world tone database
But you didn't ?
