01-06-2016 10:15 AM - edited 03-17-2019 05:25 AM
May all 24 ports in a VG310 be configured as FXO? I haven't been able to find any documentation on this.
Would like to know if this is possible before purchasing one.
Thank you.
Solved! Go to Solution.
01-06-2016 12:20 PM
VG310 is an analog GW with 24 FXS ports, and can accommodate additional EHWIC slow available to accommodate either 2,4 port FXO, FXS, VWIC:
http://www.cisco.com/c/en/us/td/docs/routers/access/vg310_vg320/hardware/installation/guide/bm_vg310_vg_320_voice/bm_vg310_vg_320_voice_chapter_01.html
from data sheet:
The VG310 and VG320 can support foreign exchange office (FXO), foreign exchange station (FXS), T1/E1 Primary Rate Interface (PRI), channel associated signaling (CAS), and Basic Rate Interface (BRI) 2- and 3-port voice interface cards (Cisco VIC2 and VIC3, respectively).
http://www.cisco.com/c/en/us/products/collateral/unified-communications/vg-series-gateways/product_data_sheet09186a00801d87f6.html
01-06-2016 12:42 PM
The only option is to get a Router (39XX, 44XX, etc) and load it up with EVM, FXO cards.
Is there no opportunity to convert the POTS lines to PRI or SIP trunk?
01-06-2016 12:20 PM
from data sheet:
01-06-2016 12:39 PM
Thanks for the clarification Chris... are you aware on any options within Cisco IPT that provides for 24 FXO ports via RJ21?
01-06-2016 12:42 PM
01-06-2016 12:48 PM
Unfortunately this is in Asia PAC and the carrier refuses to port the numbers to a PRI circuit. The client is not willing to change DIDs.
Thanks for you prompt responses.
Have a great 2016!
01-06-2016 01:02 PM
Understood. Happy new year to you as well.
Please mark the question as answered unless you have follow up question on this topic.
