02-14-2013 10:45 AM - edited 03-16-2019 03:43 PM
I have two routers set up in lab prior to deplyments router A has a FXO card(with nothing plugged into it) Roter B has a FXS card with analogue phone attached.
All tests OK, dial-peers OK and I can do test calls using csim start from Router A and B.
On Router A I have voice port configured with PLAR to automatically ring FXS on Roter B and I am sure I will have no issues when I deply.
However for scientific purposes can I test this, is there any test function in ourder I can force the FXO port and indoing this the PLAR function will ring the phone, basically I want to test the FXO.
I looked at some of the test voice port commands but couldnt get it to do what I wanted.
Any thoughts appreciated
Solved! Go to Solution.
02-14-2013 11:07 AM
Unfortunately there is no way to test an FXO within the IOS. You'll need an endpoint to perform the call setup just as you did and as explained on this document:
"The easiest empirical way to do this is to connect the FXO port to a known functioning FXS port, such as an VIC-2FXS, VIC2-2FXS, VIC-2DID (in FXS mode), VIC-4FXS/DID (in FXS mode), NM-HDA FXS, or EVM-HD FXS port on another (or even same) Cisco voice gateway. In this case, a straight-through, two-wire RJ-11 connection should be used. The aim here is to verify that one voice gateway can signal the other over the connection and draw a dial tone from the peer gateway."
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00803736c1.shtml
Tere.
If you find this post helpful, please rate!
02-14-2013 12:33 PM
Dear
You have to connect your FXO to a landed line to do a test and behind your router you can attach your cisco IP phone.
You can use debug vpm signal with "term monitor enable (If it's good, you'll see things like CALL_PROC, VOICE_CUTOVER, etc.)
which enable you track the standard debugs with Caller ID feature turned on. These debugs are analyzed from the perspective of the terminating router and its FXO port; the caller ID is sent from this end.
some helpfull commands to check you configuration
R#show voice port 1/0
(you must find the below)
Connection Mode is plar Connection Number is xxxxthank youplease rate if this will help
02-14-2013 11:07 AM
Tere.
02-14-2013 12:33 PM
Dear
02-20-2013 04:14 AM
Many thanks for the responses guys, just what I thought and rigged up a test using FXS, guess I wanted to be lazy and hope there was a function in IOS to do this.
