03-19-2013 09:23 AM - edited 03-16-2019 04:20 PM
Hi there.
Is possible to configure a timer for fxo disconnect. What i need to do, is to cut the communication at 4 minutes taking.
Carlos
Solved! Go to Solution.
03-19-2013 09:49 AM
No, you would need to create a custom TCL script to achieve that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
03-19-2013 03:15 PM
Hi Carlos,
You will need a custom TCL (as Jaime said),fortunately Paolo Bevilacqua have develop one that you could buy very cheap at this website: http://ciscoscripts.com
Call length limitation * | Allow system administrator to set duration limits for certain calls from selected phones. |
Please rate all useful posts
Favor calificar todos las respuestas útiles.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice, CCNP Voice Certified
03-19-2013 09:49 AM
java
03-19-2013 03:15 PM
Hi Carlos,
03-20-2013 09:49 AM
Thanks Guys
