04-25-2018 01:22 AM - edited 03-17-2019 12:41 PM
Dears
we face this issue , we have VG with 8 FXO ports used for PSTN calls , all these ports members of TRUNK Group which used for outside calls .when we unplug the cable from line 1 and place an outbound call, it tries to go out of line 1 and I get a busy signal and call not try to go out through second line which has cable connected
we try these settings but same issue
voice-port x/x/x
cable-detect
How can we set the router up to bypass that port if the line is disconnected with out shut this port administratively ?
04-25-2018 05:08 AM
04-29-2018 02:54 PM
Hello Nipun Singh Raghav
unfortunately ,issue not fixed after applying this command . do have any other work around tested successfully ?
