07-21-2013 03:41 AM - edited 03-16-2019 06:28 PM
Hi all ,
Can you give me a idea .. why FXO voice port status are ring-det show...
07-21-2013 07:51 AM
Try debug vpm signal and look to see if "fxols_rvs_battery" appears in the log.
Then try
voice-port x/x/x
no battery-reversal
Alex.
Please rate useful posts.
07-21-2013 10:24 PM
07-21-2013 04:45 PM
Can you please unplug the cable and plug it back,i faced same problem,it resolved after reseting cable in FXO port.
07-21-2013 11:11 PM
Sreenivasulu thanks for reply ,,,,, actually i do your propose task but its not work. Can you explaine me what does it mean Ring-det..
Avijit
11-26-2020 06:47 PM
How did you fix your problem?
unplug and plug back and still same
but sometimes shutdown no shut works
