04-24-2016 10:13 PM - edited 03-17-2019 06:41 AM
WE ordered Cisco NAME: "CISCO2911/K9", DESCR: "CISCO2911/K9 chassis, Hw Serial#: FCZ201070FU, Hw Revision: 1.0"
PID: CISCO2911/K9 , VID: V07 , SN: FCZ
We are planning to connect FXS card on it to configure Analog FAX machine below is the description of the card
Product |
Description |
VIC3-4FXS/DID |
4 PORT FXS OR DID VIC |
Is the Router 2911 support for this card..there are EHWIC1 to WHWIC3 card are available on the router can we able to connect the VIC3-4FXS/DID card on this slot.
Solved! Go to Solution.
04-24-2016 11:22 PM
Hi Vijay,
As per page 6 of the following link it is supported on 2911
http://www.cisco.com/c/dam/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/aag_c07_563807.pdf
Manish
04-24-2016 11:22 PM
Hi Vijay,
Manish
04-25-2016 12:43 AM
hello manish,
Thanks for replay...on page 6 it shows the 2901-3945E will the consider as for the CISCO2911/K9..
04-25-2016 12:51 AM
Yes, it shows the whole series between 2901 and 3945, rather than writing all of them separately.
Manish
04-25-2016 01:12 AM
04-25-2016 01:28 AM
[+5] to Nadeem.
Vijay,you can refer the Table 2.
VIC3-4FXS/DID is supported on Cisco 2900 series routers.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/ip-communications-voice-fax-network-modules/product_data_sheet0900aecd801c595e.html
regds,
aman
04-27-2016 04:56 AM
Hello Manish ,
Is the VIC3-4FXS/DID card required SM-NM-ADPTR to connect on the cisco 2911 router ...
or i can directly connect VIC3-4FXS/DID card on EHWIC port free on the Cisco 2911 router
04-27-2016 11:42 PM
Hi Vijay,
As per documentation the Cisco 2900 and 3900 Series Integrated Services Routers support Network Modules and EVM Modules via an adapter (part number SM-NM-ADPTR). So i would assume it is required but i haven't checked it in the lab so can't verify it, maybe the Cisco TAC hardware team can confirm this.
Manish
