04-01-2010 07:11 AM - edited 03-15-2019 10:04 PM
If I add an FXS card into a 3845 voice router, are there any DSP consideration?
04-01-2010 07:17 AM
Sure. The router will allocate a certain amount of DSP resources for each analog interface on the FXS card. This allocation occurs on boot up.
HTH.
Bill
04-01-2010 08:29 AM
Thank you for the Reply - Can you tell me how I can tell if I have enough DSP resources for this card?
04-01-2010 09:10 AM
You can see the number of PVDMs installed (carrier cards for DSP modules) by executing this command:
show diag | i PVDM
You can see the allocation of DSP resources using this command:
show voice dsp group all
HTH.
Bill
Please remember to rate helpful posts.
