300
mike.lo
Beginner
FXS connect to modem
Does anyone using FXS to connect modem for dial-up purpose? Is it ok?
4 REPLIES 4
paolo bevilacqua
Hall of Fame Master
supporting modem in VoIP is possible, but will require a lot of attention in configuration and is subject to limitations. Basically, there are two options, modem pass-through and modem relay.
What is the complete picture? Do you use CCM? What is the other end of the call ?
we're using CCM 4.1(3)sr3a with FXS of voice gateway C2851 12.4(3b). the modem is mainly for dial-out only with 56kpbs. the far-end is also a modem.
We're also using CCM with a C2821 voice gateway. I have modem calls originating on a PRI and I'd like them to terminate on an FXS port.
please see the following document for configuring modem relay with CCM:
http://cisco.com/en/US/products/ps6441/products_feature_guide09186a00805138e7.html
Hope this helps,please rate post if it does!
Create
Recognize Your Peers
Content for Community-Ad
