08-18-2011 12:50 PM - edited 03-16-2019 06:34 AM
We have a 3845 Router that we reconfigured for voice. Have phones in the building and they are able to dial any extension and dial outside. The router is at one location and the CCM is at another location. When we hook a normal POTS phone to the FXS port it will call any extension but you can't call it back and it will not call outside the network.
Here is the Hardwar on it:
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 13-Dec-05 10:57 by ccai
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
AltCenter-IDF6-3845 uptime is 1 day, 5 hours, 18 minutes
System restarted at 09:26:25 CDT Wed Aug 17 2011
System image file is "flash:c3845-advipservicesk9-mz.123-11.T9.bin"
Cisco 3845 (revision 1.0) with 1004543K/44032K bytes of memory.
Processor board ID FTX1011A32R
2 Gigabit Ethernet interfaces
2 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
8 Voice FXO interfaces
8 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
250880K bytes of ATA System CompactFlash (Read/Write)
THIS IS THE SHOW RUN:
version 12.3
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname AltCenter-IDF6-3845
boot-start-marker
boot-end-marker
logging buffered 16384 warnings
no logging console
no logging monitor
enable secret 5 $1$aW3X$TStOR0E5KJfk5gRjE820V/
clock timezone CST -6
clock summer-time CDT recurring
clock calendar-valid
no network-clock-participate slot 1
no network-clock-participate slot 2
no network-clock-participate slot 3
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip multicast-routing
ip ips po max-events 100
no ftp-server write-enable
voice-card 0
no dspfarm
voice-card 1
no dspfarm
voice-card 2
no dspfarm
voice-card 3
no dspfarm
trunk group pots
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service pots
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
supplementary-service h450.12
h323
voice class codec 100
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 100
h225 timeout tcp establish 3
h225 timeout setup 3
port-channel load-balance src-ip
username admin privilege 15 secret 5 $1$53aL$M/o20dEL3/VaWkM7ESfyq1
controller T1 3/0/0
framing esf
linecode b8zs
controller T1 3/0/1
framing esf
linecode b8zs
translation-rule 1
no crypto isakmp ccm
interface GigabitEthernet0/0
ip address 10.120.68.5 255.255.255.0
duplex full
speed 1000
media-type rj45
h323-gateway voip bind srcaddr 10.120.68.5
interface GigabitEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
ip route-cache flow
duplex full
speed 1000
media-type rj45
ip classless
ip route 0.0.0.0 0.0.0.0 10.120.68.1
control-plane
voice-port 1/0/0
description POTS Phone Line 210-353-1598
caller-id enable
voice-port 1/0/1
trunk-group pots
description POTS Phone Line 210-353-1599
caller-id enable
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/1/0
voice-port 1/1/1
voice-port 1/1/2
voice-port 1/1/3
voice-port 2/0/0
trunk-group pots
connection plar 5019
description POTS Phone Line 210-927-3120
caller-id enable
voice-port 2/0/1
voice-port 2/0/2
voice-port 2/0/3
voice-port 2/1/0
voice-port 2/1/1
voice-port 2/1/2
voice-port 2/1/3
sccp local GigabitEthernet0/0
sccp ccm 10.210.200.10 identifier 10
sccp
sccp ccm group 1
associate ccm 10 priority 1
dial-peer voice 7 pots
trunkgroup pots
destination-pattern 6[2-9]......
forward-digits 7
dial-peer voice 11 pots
trunkgroup pots
destination-pattern 61[2-9]..[2-9]......
forward-digits 11
dial-peer voice 830 pots
trunkgroup pots
destination-pattern 6830[2-9]......
forward-digits 10
dial-peer voice 911 pots
trunkgroup pots
destination-pattern 911
no digit-strip
forward-digits all
dial-peer voice 9911 pots
trunkgroup pots
destination-pattern 6911
forward-digits 3
dial-peer voice 9997 pots
trunkgroup pots
description Calls out
destination-pattern 6T
incoming called-number .
direct-inward-dial
dial-peer voice 9998 voip
description Incoming Call Manager Calls
destination-pattern [0-5,7-9]...
voice-class codec 100
voice-class h323 100
session target ipv4:10.210.200.11
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 9999 voip
preference 1
session target ipv4:10.210.200.10
no vad
dial-peer voice 1 pots
destination-pattern 1598
port 1/0/0
dial-peer voice 2 pots
destination-pattern 1599
port 1/0/1
gateway
timer receive-rtp 1200
call-manager-fallback
secondary-dialtone 6
max-conferences 4
transfer-system full-consult
timeouts busy 20
ip source-address 10.120.68.5 port 2000
call-forward pattern 6T
time-zone 8
We do not have the SRST license yet. We are still waiting on that.
Please, any help?
Solved! Go to Solution.
08-18-2011 02:57 PM
Jeremy,
School districts do tend to let contracts expire. Pity. However, I wouldn't give up. Get with your Cisco AE and see if they can cut you a deal to bring all your Cisco gear back under contract.
Removing the FXS ports from the trunk group should allow inbound/outbound calls to proceed normally.
-Steven
08-18-2011 01:15 PM
Jeremy,
Two comments. First, use a newer IOS. 12.3T is rather old and, if memory serves, not supported. Since you have what looks like 1GB of DRAM, try using the latest 15.0(1)M release.
Second, I notice you've made, what I assume is the fxs ports, voice-port 2/0/0 part of the pots trunk group. Why? Are you planning on dialing out of that port? The connection plar statement should auto-magically ring the phone if an inbound call for 5109 arrives. Outbound, it should match one of your dial-peers directly. Try removing it from the trunk group and see if that clears things up.
-Steven
08-18-2011 02:28 PM
Hi Steve,
Thanks for the fast response. This is a older router. It has been sitting around for a while. The contract for it is no longer active. This is a School District that doesn't have a lot of finances and they ask us to do things cheaply. I recently took over this position of caring for the network here. They have gone through two others in the past year and a half.
The router has the fxs ports as voice-port 1/0/0. The fxo ports start at voice-port 2/0/0.
If I add a plar statement to the extension I want and take the ports out of trunk group you think that will fix it?
Here is what I did:
voice-port 1/0/0
connection plar 1598
caller-id enable
voice-port 1/0/1
connection plar 1599
caller-id enable
Tomorrow when the building opens up again we will double check.
Thanks.
08-18-2011 02:57 PM
Jeremy,
-Steven
08-22-2011 06:14 AM
Hi Steve,
Thanks for the help. I have not forgotten about you. School starting and got real busy. They ported over couple of other POTS lines and used those for the fire alarm. But I am still interested in getting this working properly for next time and being able to save the cost at that building also.
I was able to get a hold of the latest IOS image and soon I will be able to finish this right and will let you know what happened.
Thanks again,
Jeremy
10-11-2011 01:25 PM
Hi there Steve, and others who were reading this.
Sorry been a while. Since they were functioning we had to move onto other high priority problems. But we did come across a similar issue at another campus when they were trying to add a fax line without any phone jacks in the building. We ran it through our network and after a lot of research and others with more good ideas also this is what we did to get the fx0 and fxs ports to work like we wanted:
Added a line to the "voice service voip"
modem passthrough nse codec g711ulaw
Then we needed to put a translation on it:
voice translation-rule 1320
rule 1 /9221249/ /1320/
voice translation-profile Fax-Profile
translate called 1320
Then adjusted those ports like you suggested:
voice-port 0/2/1
connection plar 1320
description POTS Phone Line 210-922-1320
caller-id enable
voice-port 0/3/0
caller-id enable
Also setup new dial peers for that line:
dial-peer voice 5 pots
destination-pattern 1320
port 0/3/0
forward-digits all
dial-peer voice 6 pots
translation-profile incoming Fax-Profile
incoming called-number 9221249
direct-inward-dial
Thanks for all those that helped with this. Eventhough it is a different router I am sure the concepts will work just fine.
