FXS Missing Digits
Peter Fiers
Hi everybody,
we've got a CUCM 7.1.5 here with a 2901 router as a voice gateway that has a VIC3-4FXS/DID in it. The ports on the VIC are registered with the CUCM via SCCP using stcapp. The users at the attached phones have been experiencing the following problem for three months: When they are dialing a number, some digits aren't signalized to the system. We can verify that by debugging voice ccapi and voice application stcapp. This happens on random digits, primarily on other ones than the first one. The issue has shown up without any configuration change (as far as I know), and the same construct works fine in other locations. Is it maybe a hardware issue like a faulty VIC or DSP?
Peter
Here's the router's config:
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp supplementary-services
port 0/3/0
  fallback-dn 787510
port 0/3/1
  fallback-dn 787511
port 0/3/2
  fallback-dn 787512
stcapp call-control mode feature
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw redundancy
voice-port 0/3/0
cptone DE
timeouts ringing infinity
caller-id enable
voice-port 0/3/1
cptone DE
caller-id enable
voice-port 0/3/2
cptone DE
caller-id enable
voice-port 0/3/3
cptone DE
caller-id enable
sccp local Loopback1
sccp ccm (replaced) identifier 2 priority 2 version 7.0
sccp ccm (replaced) identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface Loopback1
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 2 register RSVP-11-GW229
associate profile 1 register RSVP-29-GW229
dspfarm profile 1 mtp
codec pass-through
codec g729ar8
rsvp
maximum sessions software 100
associate application SCCP
dspfarm profile 2 mtp
codec g711ulaw
codec pass-through
rsvp
maximum sessions software 50
dial-peer voice 30 pots
service stcapp
port 0/3/0
dial-peer voice 31 pots
service stcapp
port 0/3/1
dial-peer voice 32 pots
service stcapp
port 0/3/2
dial-peer voice 33 pots
service stcapp
port 0/3/3
Chris Deren
What is the IOS version?
Chris
Hi Chris,
it's 15.1(1)T.
Peter
