07-10-2011 07:26 PM - edited 03-16-2019 05:52 AM
hi, is the FXS module EVM-HD-8FXS/DID hot swappable? i don't see it clearly stated in its white paper. or i may have just overlook or misread it. pls help confirm and cite the reference. thanks.
regards,
ramon
Solved! Go to Solution.
07-11-2011 12:59 AM
Hi Ramon,
The EVM-HD-8FXS/DID is not hot swappable. The router has to be shutdown.
07-11-2011 06:02 AM
07-11-2011 10:07 AM
Ramon,
How do you plan to connect this module "EVM-HD-8FXS/DID" and which router Model?
++ You might be inserting it into router using NM or NME as EVM ports are available only on 2821 and 2851 routers:
++ In ISR G1 Routers range only 3845 is capable of OIR(Hot Swap):
++ In ISR G2 only 3900 series is capable of OIR (Hot SWAP):
Note* in ISR G2 you will have to use SRE module, in order to connect any NM/NME module.
Amit Singh
07-11-2011 12:59 AM
Hi Ramon,
07-11-2011 07:16 PM
Thanks Payal
07-11-2011 06:02 AM
Which router do you have ?
ISR G1 do not support hotswap.
ISR G2 does.
07-11-2011 07:16 PM
I have 2821 which is ISR G1 Thanks Paolo
07-11-2011 10:07 AM
Ramon,
Amit Singh
07-11-2011 10:22 AM
Just to Add further:
++ The following items use OIR in the Cisco 3925 and Cisco 3945 ISRs:
•Service Modules
•Network modules
**Caution**
The Cisco 3845 and 3845-NOVPN router supports OIR with similar modules only. If you remove a network module, along with any installed WAN or voice interface cards, install another module and card combination exactly like it.
Same holds true for 3900 Series Routers.
Amit Singh
07-11-2011 07:18 PM
Thanks Amit
