There are numerous posts on this setup with fairly inconsistent information. Everything I read says FXS can't send dialed digit outbound and that FXS/DID functionality is inbound to the port only.
FXS can't pass dialed digits (from Cisco):
http://www.cisco.com/en/US/customer/tech/tk652/tk698/technologies_tech_note09186a00800d62d2.shtml#Solution1
I found this posting with someone running an FXS card that is successfully passing digits to a fax server:
https://supportforums.cisco.com/thread/2159478
I have a FaxFinder server with 2 FXO ports that is providing fax functional for ~20 users. I need to connect 2 FXS ports to this fax device and pass the dialed digits so the fax server can match the number with a fax email address.
Can anyone provide direction on whether this will work?
Joe
